Afc ii
Yed go get yourself dsm link. Afc can only do so much. And the possibilities are almost endless with dsm link.
ecmlink require a eprom ecu, in your case, a 2g eprom ecu.
start [ECMTuning - wiki]
This is how you can tell if you ecu is an eprom:
http://www.dsmtuners.com/forums/tuning-engine-management/176347-part-eprom-ecu.html#post1480584
epromid [ECMTuning - wiki]
the install in pretty straight up, you will need ot service or have someone service you Eprom ECU. The stock chip within needs to be removed and socketed: http://www.dsmtuners.com/forums/articles-tuning-ecu/266472-socketing-eprom-ecu.html
You can send it to ECMlink and they will do the work for you, and also set you up with link.If I were you I would get a ecu patch harness for installing logging sensors to the eCU link instead of splicing the wires. They also have easy wiring for the AFC
Extensions
Since you have a 2g, you also have the option of running a flashable ECU and tuning that way.
Ecmlink is pretty straight forward, it works the same way as the flashable 2g ecu, you program what you want and the software (ECMlink) will flash that data ontop the new Eprom chip in your ECU. The best part about ECMlink is that when you screw up you can flash stock setting back and start over. Here's a link for the demos of initial set up: ECMTuning, Inc.
goodluck
