AFC II install
killab443
602
3
Nov 24, 2003
Howell, New Jersey
I have a NEW AFC II the newest style, I was wondering when I install it will I need to tune it. OR will it work without adjusting any of the trims. In other words just plugging it in and starting the car. I just wanted it to get it in the car so I can get it tuned with it.
as long as you have stock injectors leave the hi & lo tables at zero and make sure you select the right airflow sensor type. if youselected the wrong sensor type you can puff black smoke :D
If your car was running before the installation, it should be fine. If the settings are all zeroed, it will have no effect on the fuel delivery. You may have to do a couple setups, like setting it to Karman and selecting the # of cylinders.
edit: beat me to it!
mtwollet said:
im "The Flash" when it comes to typing :)
It's because you don't use proper punctuation/capitalization! :D
I'm trying really hard to keep up on this, since people have been cracking down and complaining (on the boards and here at work).
Personally, I don't understand the difference.
personally, i dont understand the difference
Tough to read the second one??? ;)
I think it's much more distracting when someone makestypos and/or seplling errors, but to each their (or using the wrong there, their, hear, here) own :thumb:
