S-AFC II Install on 2g
DSM-Talon-John
Banned Member
296
Sep 16, 2006
Cheney, Washington
OK im installing a safc2 on my 2g and i got instructions that hucked up only 5 wires, the red, black,white,yellow, and green. I know it is working because thegreen light under the knob turns on but i cant see anything on the screen. am i missing something or is something not getting enough power?
o i just hooked up those five before i got the rest of my supporting mods, but yes i hooked up the rest laster which were red, black,green, gray,brown, pink, orange. except the purple.
I have a couple of questions for the OP.
1. What is the purpose of the SAFC?
2. Where is your logger?
My logger is in my car and its for when i get my turbo, i have injectors, i just wanted this installed first.
1. You should have install the injectors and safc together so you don't have to tune twice.
2. If you have a logger then you shouldn't be asking what the SAFC settings are, you should be answering your own question through logging. BTW the SAFC setting should be 0 for 450s.
Is that all i have to worry about, if there all at 0 then is there anything else? Its set to karman and 4 and pointing northeast, so is that about it? I dont have the turbo so thats why i didnt bother with the injectors, So i really wont have to tune twice jsut when i get my turbo in along with the injectors.
You should be fine. Just leave the settings zero'd out for now. When you put the injectors in depending on the size you'll need to take some or alot out, but thats later. Your fine for now :thumb:
