Reseting An Afc-ii
ALLeyesONmyGSX
138
Jun 9, 2004
Los Angeles, California
so i installed a used S-AFC-II on my car, and when i try to view the settings, the thing says its LOCKED--- does anyone know how to reset the S-AFC entirely? thanks :dsm:
If I remember correctly you can disconnect it where the harness on the AFC attaches to the extension harness that goes to the ecu. I'd leave it disconnected for a couple minutes and reconnect it and go from there. This might not work but worth a shot. If it doesnt give Apexi a call... good luck man.
i tried to enter 0's straight across, it says password protected... i bought the unit and it was off the original car for a couple of months, disconnecting it didnt solve the problem... is there any way to reset the entire unit? a reset button or sequence i need to press? ... thanks :dsm:
What if you left it all plugged in but disconnect the neg. battery wire. I know it resets the ECU and it might be worth a try???
