afc help
volcomsnow245
492
May 4, 2011
chicago, Illinois
should I set the graph scale to 30? I don't have a data logger right now so I'm not really able to chck anything. I have a wide band though.
I'm pretty much asking if i can leave everything at 0 but have it set up ready to tune?
You could, knowing your Air/Fuel ratio is good insurance. I would pick up a logger ASAP though. They can be had for cheap.
Yeah you can hook it up just dont tweak with it in major amounts unless you have a wide band or egt to to make sure your not too lean. a logger will help in knowing were to make the adjustments at what rpm. graph scale at 30 is ok and set the hi/lo settings to 69-70 it just works better that way and set the maf signal to karman.
any other settings you need help with?
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
