kyler021
- 242
- 178
- Aug 29, 2023
Pasadena,
Maryland
So first off I would like to say my electrical and wiring knowledge is very limited so bear with me. Should I wire the brown wire (analog -) from the AEM gauge to the sensor ground on the ECU (pin 92) kind of like a T for a vacuum line? Where I would connect the brown wire to the existing wire that connects to pin 92? I will include a picture of what I'm talking about. Would it be better to wire that to a chassis ground? I've searched other threads of wiring up a wideband and some don't even mention wiring up a wire to the sensor ground. And apparently, some AEM Gauges don't even come with a wire meant for the sensor ground on the ECU. I've also looked at the ECMLink forum post on how to wire up the Innovate gauge, and they don't mention 'T' ing into pin 92 for sensor ground.
Thank you for the help!
Kyle
Kyle
