Kurt Holsinger
- 0
- Aug 16, 2015
Farmington,
New Mexico
Hello everyone,
I got my AEM 30-4100 UEGO installed in the factory O2 location. I also confirmed that the gauge is operating and I'm getting a good signal to ECMlink. Now I want to make sure that the voltage is displaying the proper A/F ratio.
You do this by adding the sensor to captured values and then displaying it in the log. You then right click the logged value in the legend and adjust preferences for your wideband. My question is: What is the proper way to set the min and max ranges for voltage and lambda?
I have searched, believe me I have searched. There is one video for linear WB calibration here but it is set to private so I can't watch it: http://www.dsmtuners.com/threads/ecmlink-linear-wb-calibration.428702/
There are options in ECMlink to select the AEM wideband pulldown, or some just use the generic linear wideband option.
ECMlink recommends to do this for AEM gauages (http://www.ecmtuning.com/wiki/aemwb):
Says one use found this to be accurate:
Min Voltage: 0.0
Min lambda: 0.65 (gasoline A/F ratio of 9.55:1)
Max Voltage: 4.99
Max lambda: 1.32 (gasoline A/F ratio of 19.43:1)
Or for the Linwideband setting ECMlink recommends to do this (http://www.ecmtuning.com/wiki/linearitems):
Min Voltage: Whatever is displayed by RawLinwideband in your vehicle in forced openloop
Min lambda: 0.75 (gasoline A/F ratio of 11.0:1)
Max Voltage: Whatever is displayed by RawLinwideband in your vehicle in forced openloop
Max lambda: 1.0 (gasoline A/F ratio of 14.7:1)
The AEM installation manual says:
Min Voltage: 0.0
Min lambda: 0.68 (gasoline A/F ratio of 10.0:1)
Max Voltage: 4.99
Max lambda: 1.36 (gasoline A/F ratio of 19.98:1)
I used this same sensor in my supercharged Jeep SRT8 and it was calibrated by using the AEM manual settings with a tutorial found at this video:
This worked great for me. I tuned it for 11.3:1 at 9-10 psi on my 6.1 Hemi with no issues. So I'm inclined to just input these values into ECMlink and go with it. But I'm curious what the DSM gurus have to say about it.
Min Voltage: 0.0
Max Voltage: 4.99
Min Voltage: 0.0
Max Voltage: 4.99
