aem wideband install help...
greathuskie
2,666
4
Sep 10, 2002
Hollywood, Florida
ive been searching for a bit, trying to find the answer but i cant...anyways
on a 2g, where do the white and blue go, specifically? im using dsmlink, and i know one of them goes to the rear o2 sensor input on the ECU, but not sure.
can i use the stock rear o2 bung? that would be especially helpful if i could since my rear is just hanging now, and i can shut off the CEL with dsmlink if i even get one since im gonna wire it to the ecu...
thanks for the reply cool guy, but if you read my post, it says i already searched. if i searched, i undoubtedly already found taht thread, and it did not answer my question or i would not have posted. tell me in there where it says anything about using the rear o2, nor does it say anything about using the blue or white wire, only the power and ground.
next post?
Putting the sensor in the rear o2 bung is not the ideal place for it especially if you have a cat. You should have a bung welded in the down pipe. You can connect the white wire to ECU Pin 75 rear o2 for logging in dsmlink http://www.dsmlink.com/images/forums/2GECUPinout.pdf The blue wire is for serial output to a computer for logging, you don't need that one if you can log through dsmlink.
