aem wideband install
kidtsi
1,417
17
Feb 17, 2009
Laredo, Texas
I'm installing my aem wide band,i just weld a bung like 36 inches downstream and everything is perfect the only think i need to know is what can i do with the white wire? i know that i need to connect the white wire to pin 75 to the ecu, but did i need to connect a different wire to the ecu or use the cable that i just cut from the rear 02 going to the ecu? also what i do with the rear o2 positive and negative cables,just leave the rear o2 connected to the positive and negative or cut all the wires?
sorry for all this question i don't like to ask a lot to the forums but what can i do :hmm:. i already search here and in ecmlink but didn't answer my question and sorry for my bad English i'm from Germany.
You should be able to leave the rear o2 in... as soon as you cut the pin 75 wire at the ecu that will stop all comunication from the rear o2 to the ecu. then you will just connect the white wire from the widband and connect it to the cut wire from pin 75 that goes to the ecu.
