ECMlink AEM UEGO problems
Try logging it from all the different AEM options on DSMLink. There should be 4 or 5 different options on there, so just try each one till you find one close. It's unlikely that you'll get one dead on though. The UEGO just doesn't work well with DSMLink.
I know that aem o2 gauges are locked as far as being able to program them. I run jackal and I can switch what type of o2 input I'm running. Like I can program my software for voltage from the ecu from around 0 volts =7:1 afr and 5 volts= 21.7:1 afr. I pulled my aem o2 gauge out and switched over to a lc1 unit. It has programable outputs and less 'bling'. See if you can change gauge input to programmable and just edit the voltage to match what the gauge reads
