AEM AEM EMS SERIES 1 knock
Now, I did actually swap from magnacore plug wires to ngk. To make sure my sound was cam and not a miss. I wouldn't think that could cause the knock ? Both sets of wires are new.
I think this is the first time I logged a wot 1-2-3 pull also
Should I be paying attention to knock raw ?
Do you know what Idle Learned is? Also, what did you figure out from playing around with the percentages on the Idle % vs RPM table? Knock volts is better than knock raw but you can monitor both. The difference between volts & raw is when the EMS takes the sample. Knock volts is suppose to sample off the ignition event where raw is just sampled along with the other things you're logging.
Well I checked plugs to be safe, all look good. Decided to do a BLT. Had a few tiny leaks on intake fittings. And a HUGE leak at the throttle body elbow coupler. Nothing major after tb. Was hoping it was , and would be my idleing issues LOL
Fixed all that holds 25psi bleeds off in 30-40sec or so (air compressor fittings leak also). Still think a have a tiny leak at tb shaft seals even though it was just rebuilt.
So on the idle% vs target table. Was I not supposed to adjust table @ 3k rpm, Say 3000rpm target. To idle at that rpm, and keep going down etc ?
That may be my issue then with that...
