adjusting 16g compressor housing
tristanmb81
232
Nov 20, 2007
virginia Beach, Virginia
Hello, I'm installing my 16g turbo, but I ran into a slight problem. The J-pipe's angle is too forward and it hits the fan housing. Now, my question is can I rotate the compressor housing on a 16g so the J-pipe would have enough clearance? Thanks!!!
Tristan
I kind of figured that while evaluating the position. Wastegate rod would either rub or stick, then I guess I would have to hack my J-pipe. Thanks!!!
Tristan
You should use a RRE 16g J-pipe . It places the outlet in the stock T25 outlet location but no 90 degree elbw so you can use either a FMIC or Stock SMIC. It clears the fans perfectly. I think I have one laying around if you want it.
I would like to buy it from you. Let me know how much and I'll pay you via paypal, if that is good? Thanks!!!
Tristan
