14b+16g compressor housing,and wheel=?
danwheelspin
90
Jun 29, 2002
I just bought a 16g in need of a rebuild.Instead of a complete rebuild,would this work?A 16g compressor housing,and wheel,put on the 14b shaft and center piece(where the lines go to).Also, is the 16g exhaust wheel the same as a 14b?I have a ported 14b exhaust housing, and I know that will fit.Theres a Diesel shop around that can balance it .The only reason for this idea is that it would only cost me $200 total,thats including the balance.Ive search,but could not come to the conclusion if it would work. :| So it boils down to this, 16g compressor housing,and wheel the rest 14b,,,,would it work. :)
sure it will work.. just remember by using the 14b turbine housing your spool up will be faster but top end reduced.
^^^ this will happen if you use the 14B turbine housing. The 14B's housings are 6cm^2, 16G's are usually 7cm^2. Better spoolup, but chokes easier on the top-end. Since they're both TD05H turbine wheels, either housing will fit - your choice.
I don't think you can use the 14B's compressor housing unless you machine it to accept the 16G wheel. You'll probably want to use the 16G comp housing.
I used the TDO-5H 14B, and had it rebuilt and converted to the 16G wheel. :thumb:
And yes the turbo shop had to maschine the TDO5H-14B housing to fit the 16G wheel in it. :dsm:
I planned on using the 16g compressor housing,and wheel.The 16g I bought was a complete turbo.Now I just need to take my 14b off and switch parts,then get it balanced.Thanks all for the info.
