Resolved Adjustable Cam Gear
does anyone know how to put the cam at tdc with adjustable cam gears. my friend took it apart and cant get it together.
You will just put the hash marks at 0 on the gear, and then put the dowel pin at 12 o'clock and that will be set for the cams.
also, what gears are you running? The fidanzas have a spot for the EVO and DSM dowel pins, just make sure its in the correct one because if its not the cam timing will be 90* out.
