Added DSMLink, won't start
000triple000
Sep 6, 2010
lima, Ohio
I got my dsmlink v3 now and I put the chip in my car and the car wont start now, It runs with the stock chip in it, but it just fowls out the plugs. I got the dsmlink chipped preset for stock 450's and a 2g maf, with a 2g dsm package. My mods are 2.3l stroker, 92 6 bolt swap, fully built for track. I will add a log in that I took last night of me setting my throtpos and tring to crank the motor over. Let me Know if you guys have any ideas. I have fuel and spark, it also just turns over all day long. Let me know if theres anythign you guys can see wrong. 95 eagle talon tsi 2g ecu.
Make sure you check all your connections. I know its something simple, but that might be the issue. Fuel pump acting right?
yes i agree it is something stupid and retarted and small LOL. But yes i Have changed my plug wires to the right diagram on that link. So I know there setup right. Car does run with stock chip in. The only thing acting funny is my fpr. it needs adjusted, it rund 30psi on idle and when you take the vacum hose off and adjust the nut it doesn't do anythign. but there is fuel and there is fuel getting to the rail, and also on the dsmlink log you can see my injectors pulsing and the injector duty.
