ACT 2600 clutch and Fidanza flywheel combo
91_laser
100
Jun 23, 2002
Stoughton, Wisconsin
I have a question to anyone with this in their DSMs. I was wondering on the step height of the fidanza flywheel has anyone had one that had a smaller step height then the recommended height?
Fidanza is rather well known for their iffy QC. Get it replaced.
I have replaced the master cylinder, slave cylinder, shimed the slave rod, adjusted the rod under the dash. The clutch will not disengage after all this. I read all around and on road race engineering they stated the if the flywheel step is to shallow there is no room so the clutch to disengage. when i recieved the fly wheel i put the sock on and the fidanza fly on a level surface and noticed a bit of step difference.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
