ABS question on a 2g
1995 AWD
38
Aug 8, 2010
Joplin, Missouri
Alright so I've got to replace a spindle due to the axle being stuck in the hub. I'm shopping around now but I'm not sure if I have ABS. Motors out of the car. I looked at the fuse box to maybe see if I saw ABS marked on it. It does but I'm wondering if that's just standard on all fuse box covers cause I pulled it and didn't see a fuse. How can I tell if I have ABS or not? Any distinguished look from ABS to non ABS knuckles? It's a 95 All wheel Tsi
Thanks
Look behind the driver side headlight. IF there are break lines going to that location than you have abs, is there are none than than you don't.
This is about all I can find before I pulled all the brake lines. The only lines I see near the power steering reservoir is the ps line.
[/IMG]
Right on, well I found a new spindle non abs but it's off an Avenger. It looks almost identical except for the bearing bolt pattern by just a hair. I wonder if it'll work.
The 96 Avenger and 95 Eagle Talon spindles match up identically. I pulled the wheel bearing when I got back from the junk yard and matched the bearing bolt holes at Autozone. This stuck axle is no longer an issue. Thanks for everyones input.
  • For sale 2g 2g rear brace arms
    2g rear subframe brace arms. Missing one of the bushing spacers. No rust. Had someone looking...
  • For sale 1g 1GB Eclipse Tail Lights
    1GB Eclipse Tail Lights $80 + shipping and paypal fees* not flawless but in very good shape...
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
  • For sale 1g Flip up headlight
    One red flip up headlight and the black trim piece for the other
    • Anthony Hornback
