94awdcoupe
- 1,416
- 217
- Nov 6, 2004
tampa,
Florida
has anyone done this? would love to convert my evo 1 to auto. but it lifts front end too hard to be without a front LSD.
I run a welded centre & a switchable transfer case. Quaife ATB front & viscous rear lsd.
In fwd Quaife atb lsd mode it's an animal, but I gotta say, Love That Car ;-)
If you run a lower front & std rear height, your lift will be less & it won't power steer.
Cheers !
You need to swap the ring gear, and bearings. The down side is you'll need to run FWD axles as well.
I know the FWD Quaiffe made for FWD 5spd fits the A/T FWD trans. but does it fit A/T AWD?
LSD for AWD 5spd is same as early 89-92.5 FWD trans. the later FWD trans 92.5-99 used a larger axle.
