A Question About Factory PISTONS.
Status
Not open for further replies.
xsabrewulf
246
Mar 28, 2003
Ok, Are the FACTORY piston FORGED? or not?
I am thinking about doing an engine rebuild.
And I was wondering what was the ADVANATGES to have FORGED PISTONS.
forged pistons are better because they are alot stronger they mostly good for nitrouse or big boost where a stock piston may shatter
And Now the LAST question....
How much more MONEY does FORGED pistons cost?
compared to regular pistons?
Well a quick hop to a dsm vendor site brought this up.
Pistons and Rings 95' 8.5:1 pistons (specify bore size) $268/4
95' rings set $150
Lancer EVO 8.7:1 pistons $290/4
Lancer EVO ring set $140
JE racing pistons (specify size and ratio) $525/4
JE moly ring set $80
Arias racing pistons (specify size and ratio) $525/4
Arias moly ring set $80
Ross Racing pistons with coating (specify size and ratio) $650/4
Ross moly ring set $120
Ross street pistons set with rings (specify size and ratio) $485/4
why do you CAPITILIZE some of your WORDS like PISTONS and MONEY?
anyways, as said before FORGED PISTONS can resist heat and high COMPRESSION caused from alot of BOOST, another THING to look into is forged RODS
Originally posted by xsabrewulf
What ADVANTAGE does Forged Pistons Have then?.
They're cheaper and easier to make in small quantity as opposed to cast pistons. After-market companies don't crank them out _only_ because they're "better" (some aspects are), but they're not set up to tool the molds and cast up batches of a few hundred. They can have a thousand slugs hammered out, then cut pistons to fit a broad range of cars from those forgings- especially in these days of automated machine shops -for much less than making the dies for cast DSM pistons.
Where can I buy forged pistons and premium rings. and rods.
online.
I looked at slowboyracing.
where else? that I could get them for cheap?
you know I have never onced told someone to use the search button or anything like that but damn. This a huge and very broad subject/product man just hit up google type in je pistion for dsms or somthing along that line and you will get over a million sites with them. I hate being a nice guy somtimes LOL;) :D .
www.dsm-performance.com
www.buschurracing.com <--book mark that one.
www.dsmparts.com <--they sent me the wrong bolts with my 1g bov flange.
www.import-palace.com <--very cheap.
thats all I'm giving you LOL also JE isnt the only company out thier is wiesco,ross,cp,and SRP. search man cause you'll get hella flamed if you dont put forth the effort hope thats stuff helps good luck.
mitch
Status
