Question about used rods and pistons
Biddy420
155
18
Jun 17, 2017
Naperville, Illinois
ok so a buddy of mine built a motor he bent a valve during break in and ended up parting out the car I bought the rods and pistons for my build they are in great shape and were only used around 25-30 miles of break in. So my question is are these safe to run anything that I should replace they are eagle rods and mahle Motorsport pistons the pistons are a 9.01 compression piston I already bought brand new rings from mahle
honestly if you had your block bored for that set of pistons, you could run everything as is. rings, pins, bearings. 30 mile isnt enough for any of that stuff to have any seating yet. as long as it wasn't damaged by what ever caused the valve to drop, metal shards, etc.
if you are going to replace the rings, replave the rod bearings also, do not separate the pins or anything else though.
