A non DSM question
Redslayer
201
5
Apr 5, 2012
Federalsburg, Maryland
Long story short my brothers truck (02 I think, Cadillac Escalade).
I've been searching the net a bit to see if I could find something concrete enough to suggest to him. Figured I'd ask here in case one of you knows what could cause it.
It wont start, it turns over and you can smell raw fuel after he turns it over for a few seconds (strong from the exhaust) then when he releases the key, it will act like maybe one or two cylinders are trying to fire for a few seconds then stops, sometimes it will act like its going to fire when he first turns the key, and then just turns over. And then does the chugging when he stops trying.
I've never actually ran into this one before, never seen a vehicle do that after trying to start. So any idea what would cause this?
Sorry for the non DSM related post, but I'm at a loss here, and I am not part of any other car forums LOL.
Gonna ask a dumb one here: Did he pull plugs and maybe cross some plug wires or something?
Firing order, if it's a 350, or 5.7L (actually, any V8 from GM) would be; 1-8-4-3-6-5-7-2.
Also, wonder if the cam chain took a slip causing cam timing to be off...
That wouldn't explain the weak spark. I would pull the distributor cap and check out the contacts inside the cap and on the rotor. I've seen a few of these vortec engines with the tab that makes contact on the cap worn off. I would also test the coil wire with a multimeter to verify that it is in good condition.
Thanks for all the suggestions guys :)
No wires crossed, he did at first but we sorted that. Its raining on and off now so its gonna sit for a few days I'm sure.
Check the fuel pressure. Vortec engines must have specfic fuel pressure, 5psi too can cause that sometimes. Also 2002 escalades only came with 5.3 or 6.0 not 5.7. I don't think any escalade came with 5.7. Fuel pressure for 2002 escalade with 5.3 vortec is 55-62. If its lower then you need to change your fuel pump.
The motor in the picture is obviously a vortec 5.7. The throttle body on top of the engine and lack of coils on the valve covers are a dead giveaway.
Check for fuel pressure! I can almost guarantee that the pump is going out from watching that video. Also check base timing just to be sure so you can rule it out. But I'm gonna say its a fuel pressure issue. Might also be the distributor.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
