STI2TALON
- 59
- 0
- Sep 15, 2007
Sharon,
Pennsylvania
I have a 1996 Talon AWD with a 1 bolt swap. Well my engine bent valves back in november due to a timing blet slip from a faulty tensioner. I pulled the engine, had a reputable shop put it together with all new everything... heres a list of the mods:
Engine:
-complete 6 bolt swap from a 1g
-eagle rods
-cp pistons (.040 over , 9.0 compression)
-all new gaskets, rings, bearings, etc
-all new belts, OEM mitsu timing belt
-all new waterpump, tensioner bearings, hydraulic tensioner
-brian crower stage 3 cams
-brian crower titanium valvesprings and retainers
-3g "revised" lash adjusters
-Coil on plug ignition
-Adjustable cam gears set to 0 as a baseline
Transmission:
-Tranny Rebuilt by DogBox Racing
-Symborski Shift Kit
-B&M short shifter
-Solid Shifter Cable Bushings
-ACT 2600 Clutch Kit
-ACT XACT LightWeight Flywheel
Exhaust:
-Ported 2g Exhaust Manifold
-JMF SS Heat Shield
-o2 Housing Dump
-3" SS Downpipe
-Apex-i Cat Back
Intake:
-3" Intake
-SBR 50 Trim turbo with about 10k
-Greddy 24R Frount Mount Kit
-Dejon Upper Intercooler Pipe
Fuel:
-walbro 255 Pump
-FIC 650cc Injectors (to be swapped out for FIC 850CC)
-Aeromotive Fuel Pressure Regulator
-B&M Fuel Pressure Gauge
Tuning:
-Stage 3 eProm ECU
-AEM Wideband with new Sensor
-Apexi SAFC II
The battery is currently relocated to the spare tire well in the trunk.
The shop that put it back in had problems with the electrical system but eventually got it to fire up. It idled very roughly, jumping up in down from 1000 to 2000 rpms rapidly, and sometimes just plain idled really high, like around 2700 rpms. They told me this was because of the cams but Ive since learned on here its because of a faulty tps. Sure enough I got a tps CEL. Then my engine would run worse and worse until it just shut off, sometime lasting only 10 blocks. It seemed like it was overheating. I replaced bothe the tps and the coolant temp sensor (which also had a code that popped up) along with the coolant temp sender just while I was down there in that area.
Now the car doesnt start. It doesnt even begin to turn over. It cranks all day and I can smell fuel but it seems as if it gets no spark. Plus the throttle % on my SAFC shows 9.5 % right off the bat at startup instead of 0% like it did before the replacement. I get tuned may 12, i need to have the car run by then. Any suggestions? Thanks, Brandon
Engine:
-eagle rods
Transmission:
-B&M short shifter
Exhaust:
-JMF SS Heat Shield
-o2 Housing Dump
-3" SS Downpipe
-Apex-i Cat Back
Intake:
-3" Intake
Fuel:
-walbro 255 Pump
Tuning:
-Stage 3 eProm ECU
-Apexi SAFC II
