a little HELP here with CAMS?!?!
DSMinn0vati0ns
193
Sep 26, 2004
Budd Lake, New Jersey
Quick question.. ive been searching for the perfect cam set up for my applications.. i wanna run street/race cams, however i do not know which ones to get and wut size.. if anyone could help me out with this ASAP that would be great.. thanks all
i eventually plan on installing a 20g turbo but for now im just gonna install the cams.. i was thinking hks 272's? or maybe the stage 2 crowers but i want good street/strip aplications...
Does the FPgreen work well for street as well? when does is start to spool and gain its full boost?
Honestly thats like asking how long a piece of string is. It really depends on how you have the car set up. Every car will be a little different. However to give you an idea a friend of mine with a 95Gst that had stock cams and all external supporting mods was at full boost right around 4k.
ok.. the turbo upgrade is later down the line.. but for now its the cams.. i have basically all fuel support mods besides a FPR and bigger injectors.. however im ordering denso 660's..
So wut is a good set up.. like whats the difference between a 264 intake and a 272 exhaust and with a 272/272 match.. like someone explain this to me.. im going nuts.. Like how do u figure out wut a good cam size will suit u good.. help?!
You're going to put in new cams...before you upgrade from the T25? Or is something missing in your vehicle profile? :confused:
