A Fresh Start.....
Vadyr
37
Jul 11, 2010
Queen Creek, Arizona
O.k. So I'm on my 3rd Eclipse in less than 3 months. 1st one crankwalked:confused: 2nd one had a blown motor:notgood: and now I find myself with the 3rd one. This one actually already took a big dookie only 93 miles after I bought it from the dealer. However after having it towed to the mechanic of their choice, waiting over a week for parts to come in, it seems to be running o.k. for the time being. More on that later though.
So here's my thought. I've already started the maintenance log and changed out some parts that I knew would need to be changed between 60-90 thousand miles. It has 97 K so I figured I wouldn't take a chance on the former owner doing what needed to be done.
So, now I want to make it a bit more responsive. It is however an Automatic. I will be ordering Tokico Illumina shocks/struts all the way around and will drop it about 1.5 from its stock height. I'm looking for some direction on what I should do for more engine responsiveness. I've seen threads about Manuals, but nothing about an automatic. Are they the same? With the standard Air Intake, FMIC, Battery, Fuel Pump, ETC.? Any assistance would be greatly appreciated.
Torque Converter is a good idea but basicly do what you want just like a manual. You know upgrade fuel pump, turbo, intercooler, injectors, and read read read. What did you do with the other two cars?
Very clean. My brother has a 98 GST/manual. The engine is dirty as hell but it still runs strong with over 100k mi. All he added was HKS cat back and upper/lower icp. I figure if you do the simple bolt on mods you'll be happy with it for a while. How much did you pick it up for if you don't mind me asking?
The other 2 Spyder GST's are sitting in my backyard still. I have them both covered and will probably build at least one up and sell the shell of the other.
I paid 4900 for the White GST. It is extremely clean on the inside, and body only has a few door dings. It is also completely stock under the hood, radio, interior. All electronics work great too.
Don't feel bad I'm on my 5th DSM...Good luck with this one...A piece of advice though, plan out what you want out of this car (and the others) before you start buying parts. That's were most people (myself included) tend to go wrong :banghead:
Great job on finding an unmolested DSM. I too just picked up my 3rd DSM (and third automatic) that was never modified. Its funny to see the big huge black thing under the hood called an airbox.
Talk to John at IPT, he is the "GURU" of the auto world, basically the Shep for automatics. I would go with an aftercooler piggybacked on the stock cooler that way you can brake boost (briefly!!). Other upgrades are about the same, I put down 383 with my first auto DSM. The 16g is a great turbo on the automatic and a good turbo for DD.
If you ever have questions about mods, or the automatic shoot me a PM anytime. Good luck on your 3rd round!
Congrats on the new car(s), and as everyone is saying, do the same mods you would to a stick.
I also don't suggest swapping over to a 5speed considering the ammount of work needed,parts costs, etc.
It should also be pointed out that a lot of 5-speed guys are swapping to automatic trannies for drag purposes, so IF you thought about swapping it, maybe talk to one of them?
But yeah dude just do basic bolt ons and you'll be happy (for a little while anyway). What maintenance have you done so far?
I really hope you don't go with the guys that say swap out the Auto. What a waist in my opinion. For the money that you would spend on doing the swap you could put some IPT parts in and have a killer auto. On my last GST I had a duel stage so I set low boost for 1st gear launches, then once the auto hit 2nd, hit the switch for high boost and hold onto the steering wheel and try to keep it between the lines.
Look around on the forums and ask some of the other guys that are running automatics, launches are perfect almost every time, we can generate boost at the light before launch, and they can shift faster than any 5spd. Good luck!!
You mean transmission cooler, Yes they are great for turbo auto's and 420a automatic. Add a transmission gauge to keep an eye on temps.
Look into a shiftkit also, from IPT or transgo. These three items are fairly cheap and will extend the life from the auto.
Nice 2g, when I look at it or other white 2g's makes me miss my old white 2g nt. LOL
Not everyone is into drag, and automatics just arent fun at all in the twisties......
though agreed, if you buy auto, might as well keep it. If you get the hankerin' for a stick, buy a second DSM. I wish now that my GST is relegated to being a DD that I had gotten an auto, but initially i bought the car for top-down twisty action and awd swap.........oh how things change. Auto's are great for DD'ing though, especially in stop n go traffic.
Hey guys, thanks for all the information. I really don't want to change it to a manual as I have 2 manual spyders that I can work with putting back to together.
I took the car the UMS Tuning and had them go over it to give me a list of what needed to be changed. They actually changed the Original Plugs and Wires (11 years old), checked the oil sending unit (the gauge was not working right, now it doesn't work at all), and then I got a list of things. I need to change most hoses (already ordered a full set of Silicone Replacements for most hoses, vaccuum lines), I have a leaky head gasket, and Oil pan gasket. Turbo coolant lines need to be replaced. Replaced the fronts fans already, new thermostat, changed all fluids.
What about the stock exhaust? Doesn't that restrict alot? Aftermarket fuel filter or lines? I have a Walbro 255 that I can put in, but I thought I would have to put in an adjustable fuel pressure gauge first and upgrade the injectors 1st. Also what about a FMIC?
So, if I put in order what I should do
1. Maintenance
2. Torque Converter
3. Transmission Cooler w/gauge
4. Shift kit
5. Aftermarket Air intake
6. Fuel Pump
7. Injectors
8. Battery (I already have a killer stereo that will be going in)
9. Gauges (I know I need an oil pressure, then a tranny temp?, Boost/Vac?, Exhaust temp?)
10. Turbo
Does this seem like an o.k. order? Or do I need to switch something around.
Good looking list. I am a personal fan of 2, 3, 4. I wouldn't mess around with the injectors, and fuel pump untill your ready to do the turbo. Stock exhaust from the o2 housing back could get ditched for something. For your guages the two most important IMO is Wideband/boost, the others are gravy on the biscuit :thumb:
If you thinking about changing the turbo, wait on your O2 Housing, FMIC, and Intake. You might bounce around between 3"GM/MAFT setup, short route, long route FMIC, and then there is 100's of turbo options from mild to wild. Different turbo's have different configurations for manifolds, and intercooler routing. Don't forget tuning options in your build ideas.
In looking into the Torque Converter. Do I get the 600.00 one or the 1100.00 one for a daily driver?
My guess is the one that is $519, but you need to talk with John at IPT. He will build the TC for what you want/need. Just a side note, I didn't know that you had to fill the TC up with fluid before installing and I think that might have been one of the causes to my catastrophic failure.
Im glad you said that. I didnt know that and just finished a awd conversion and workin a 63/64 hybrid. Ill do that before i stick it back in.
