a frame bent
nickbrotha
Nov 21, 2011
slc, Utah
I hit a curb and bent the passenger side lower control arm . its a first gen awd talon . i found one at the junkyard and it seems real simple to swap it out but thought id ask if theres anything i should watch out for, special tools ill need, or any advise from someone thats done it before . thanks !
A frame....I'm gonna go with lower control arm, cause it looks like an a frame LOL.
Just check your outer tie rod as well.
Get a junkyard one and make sure the bushings are good to go and swap it out
Oh:ALUGNMENT-> get one of them too at a service station
ya its the lower controll arm , im not a mechanic haha sorry . stuck on caliper bolts right now currently soaking in pb blaster . .(theyre not reverse threads or any bs are they?) . got the controll arm off almost , but it seems i have to get the rotor off to take apart ball joint (still not a mechanic ha ha feel free to teach me what things are really called) ha thanks guys
ive edited the post with the correct name of the part now but i dont know how to edit the title , sorry . and i'll try and use better gramar
today went well . i got a controll arm from the junkyard for $35. it went in without any problems and everything seems fine . i test drove it down to the junkyard and found a matching rim for $50 (the other one seemed to hold air fine but it does have a nice dent). then went down to discount and got 4 brand new tires for $99 out the door !! the guy hooked it up for sure :). and now i have a spare !
