b15turbo
- 71
- 0
- Feb 1, 2006
Columbia,
South Carolina
Ok, I got a AEM wideband and I got is tuned good where is running 10.9 to 11.2 to the red line, and i had my stock boost gauge converted to knock from eprom ecu. My problem is that the knock gauge pins to 14 witch is around 15 counts of knock running 19psi.
If I go richer to around 10:1 it still knocks if I go leaner to like 11:8 it still knocks I don't get it, anybody??? The knock does not go down either way I go, Can the solid motor mounts cause the knock to pick up on vibrating things in the engine bay? Should just leave it at 10:9 a/f and don't worry about it?
