99 wiring harness help
avaien
242
24
Nov 30, 2003
Cincinnati, Ohio
I have been attempting to reinstall my wiring harness on my 99 m/t gsx. I have ran into a few connections that I cannot find for the life of me. I have used
https://www.dsmtuners.com/threads/2g-engine-bay-electrical-connections.298047/
to help me so far.
This is part of the starter harness
Driver side
Passenger side by the transmission
Also this is a 6 bolt swap with 2g head. It looks to me like picture 2 is the crankshaft position sensor. I bought the cas adapter harness from RRE, is that where it plugs into?
The third one I have zero clue. But the first two are definitely in the thread you linked with associated colors.
I will help anyway.
The first one is either the starter trigger sensor (on the starter) or coolant temp sensor on the t-stat housing.
The second one is probably the CAS, but again, its on the thread you linked. I can't tell without knowing the colors.
Third plug I know I don't have and I have a 99 M/T GSX. My harness is hacked though.
Good luck.
The fist connector is for the starter (male side) and the third one is the starter ( female side) so just plug it into the other.
The second is the cam sensor, at the engine cover there are 2 lines coming out so one is cam and the other is crank.
CORRECTION.
I just realized it’s 99, so there is only one harness como Goff the front cover which is the crank sensor harness, and that connects to the plug you have on pic number 2.
Thanks for your replies. Any idea what the orange plug is in the third picture? It is off the same branch as the speed sensor and water temp gauge sendor I believe. It looks just like the cruise control plug in the link but I already have that one hooked up.
