99 GSX GEARBOX
jason6989
Apr 21, 2013
Manama, Arizona
Anyone have an idea about the 5 speed GSX gearbox, is there any other gearbox that would mate with the 4g63 engine or if i need to rebuild my gearbox would there be any other alternative to get the same gears from another gearbox... since im located in the Middle East and i dont think theres another GSX here..
Many things interchange. Why don't you tell us what your problem is and what car you have? if you have a 99 gsx only the 97-99 trannies are are a direct swap. If you use a 95-96 you need a 91-96 transfercase also. If you're choosing to take the tranny apart and replace what's broken then may parts are the same over the years or can be swapped. It depends on what you're trying to do.
