99 GS-T auto radiator?
coradojr89
54
Oct 22, 2008
Oxnard, California
does anybody make auto performance radiators? have been looking with no luck. please help out. thanks!
You best bet is to get a regular racing radiator such as like CXracing then get a high performance trans cooler. It will make things simpler to separate
I looked into this a bit when my car was an A/T and never upgraded my radiator because I was planning on going to a M/T. I decided there were two ways to go about doing this the right way, the first option was to get a aluminum rad. and then weld in provisions for the A/T cooler, the second was going with an aluminum rad. and then getting a seperate trans. cooler.
Here are a few threads about the subject.
A radiator is a radiator..It does not matter if it's for an auto or not...
I wish that was the case Bud, but its not. The A/T radiator has provisions in it to run coolant through the A/T oil cooler and no aluminum aftermarket radiator includes them for the A/T DSM'rs.
:dsm:
I pulled an auto trans cooler off a N/T Spyder, it was mounted in the driver opening on the bumper. Are the turbos different?
Chris, if its a N/T Spyder then yes the turbos are different because the N/T Spyder doesn't have a turbo to begin with. ROFL
:dsm:
I'll go look under my cars when it stops raining but my automatic turbo spyder has a separate transmission cooler which I'm almost certain has no provision to tie into the radiator. I haven't spent a lot of time under my 1g automatic but I think that it may have a different radiator than 1g manual cars. Like I said I'll verify when it stops raining.
Even if for some reason I'm wrong about 2g automatic radiators it shouldn't matter because long before you actually need a performance radiator you will definitely need a high performance transmission cooler so you might as well go ahead with that.
On my 2GA N/T it has the cooler inside the radiator. Ive always seen that aftermarket coolers for oil and trans do the job alot better than a trans/coolant radiator
On your 99, it has a separate tranny cooler, you can use any radiator you want.
:dsm:
Weird but mine doesn't have that..Either a previous owner removed the lines or they just went to an upgraded oil cooler for the tranny..Would that remove the lines for coolant to run through the tranny oil cooler?
I just did a radiator swap, and only had two lines to remove, the upper and lower radiator pipes..
My 2g radiator has provisions for a trans cooler built into the bottom after thinking about it.
Corey, you got me on that one!
    • george bromwell
    • pma1123
    • Sdcryan1
