98 Gst Whats Wrong With It?!?!?!?!?!?!!!?????
Jdubz
May 4, 2008
Roc, New York
Hey guys PLEASE HELP ME PLEASE
I just recently purchased a 98 GS-T it runs good doesnt have problems until i get on it... then once i get on it for some reason it wants to bog out and doesnt wanna go anywhere. sometimes it also likes to cut off like i hit redline but im no where near that and when it doesnt hit redline my boost gauge spikes way past 25 psi and pins it self at the bottom of the guage... my check engine light also recently came on and when i got it checked out i was told that it was my TPS would this cause all of my problems????
Start with learning to spell. There's no way you can boost to 25 without some sort of mod. Now when you say tyle do you mean TIAL? Also what's the code on the CEL?
if you are hitting 25 psi, then that redline feel your feeling is fuel cut. check to see if you have a manual boost controller(maybe when you got it, he never told you,LOL) also check your plugs, and report back.
the guy that you purchased the car from; did he tell you that the car was stock? or are you assuming...
1. replace TPS and adjust it
2. is your timing off
3. could be a bent valve (hope not tho)
4. definitely run a boost leak test
might as well throw some engine pics up so we can see what we are dealing with...maybe theres something in there you dont know about...
it does sound like your hitting fuel cut...
BLT FTW!!!
Thanks for everything from everyone this is my first DSM so its gunna take me some time to figure everything out. Im gunna try what everyone suggested and ill let you guys no what happens thanks again
