2G 98 Eclipse heater will not work
bboyroxas
65
Sep 5, 2012
gallardo, Tennessee
So now that it's getting colder I want to use my heater but here's the thing my engine does not reach temperature on the cold and so the heater will not work. My car stays cool in the summer so what could that be is it the thermostat?
Most likely your thermostat is stuck open had the same problem from my 1g a few years ago. Check your coolant level also if its low then it will get air into the system and will not circulate propely. Hope that helps
What's a good thermostat to buy because it's so cold here is ther a specific range in Celsius
You may have a blocked heater core. My gf has no thermostat in her 95awd talon. It heats up just fine.
Sounds like your heater core isnt getting circulation. Or your door isn't opening.
