98 eclipse cas need help!!!
dcboosted2
Aug 25, 2019
Cheyenne, Wyoming
I have a 98 eclipse gst all stock bought it as a shell so then I bought a 96 eclipse gst to put the engine and trans in well i found out that the cas is different on the 98 and 96 the 98 i have the cas is a first gen. The photos below are the case thats in it is there a way to make it work on the 96 engine the small wire from the cas itself is only one wire that goes into the connecter in the harness is there a way i can maybe cut the connector and wire it to the cas on the 96 case? I also dont have the 96 car anymore the harness from the 96 was actaully cut was kinda melted also not sure why but from the firewall to the engine bay I have all that harness and the ecu hopfully someone can help me with it
In that post it says I dont know how to do it without dsm link.... I dint have dsm link i made anotger post to see if someone did do it without it....
This is from the link u sent me i read it yes I'm asking for help to see if some one has a idea to the cas the 1g on it now i can take off and i can plug it into the stock 98 car but in this case i need help to get the 96 cas to work on a 98 cas harness or a more simple way with a 1g cas WITHOUT A DSMLINK
Now go ahead and put the valve cover back on, and put your spark plugs back in. Now to use this cas you have to reverse the order of the spark plugs. From left to right, your cylinders are 4-3-2-1. The normal setup of spark plugs into the coil pack from left to right is 4-1-2-3. You need to reverse this so the order on the coil pack is (from left to right): 3-2-1-4. In DSMLink make sure "Invert CAS" is selected. I'm not sure how to do this without DSMLink, so someone please post up if you know what to do. Connect your wiring harness to the new 1g CAS and to the crank angle sensor and cam angle sensor on the wiring harness.
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
