420A 95 RS GS Rear HUB same as GST?
The GS and above should be the same I beleive. The Rotors and wheels are the same. The RS line will have drum brakes, without ABS and may cause some problems. You will need to make sure that the hub you get has the ABS Tone wheel on it.
Doug
