95 gsx- 6bolt jdm engine swap and ecu Q
zponce
Sep 28, 2012
winchester, New Hampshire
I have a 1995 mits eclipse gsx awd turbo. I just received a JDM 6Bolt (1st gen) motor and was wondering if you know what has to be converted over to make it run prperly here in the states?
--I know its a 95 so it doesnt have to pass emissions
Also another question: It has the stock ecu and wiring harness. Can i still use those? I dont think i can because they are diff models and it wont be able to be tuned without the 2nd gen ecu and wiring harness and the e-prom or work properly.
What do you suggest?
Thank you
Zachary Ponce
Ok thanks! Do u know what sensors exactly need to be changed?
And do u know where i can get a 2g wiring harness and ecu? besides a junkyard or straight from ecmlink for the ecu
