jdm 4g63t engine and tranny swap to 92 eclipse gsx
untunedgsx
Sep 10, 2004
st paul, Minnesota
I'm just wondering if anyone here has done a jdm 90-94 4g63t :dsm: eclipse engine and all wheel tranny swap to a 92 :dsm: eclipse gsx. If so what parts would I need to changeover? And does anyone have any suggestions where I can get a deal on an engine and tranny?
i am planning on doing the exact same thing very soon (next couple of weeks). mine is a 93, but same deal.
as far as i know, it is recomended to swap the original intake manifold onto the JDM, mostly because the cyclone part won't work, and the coil pack needs to fit. i also recall something about the oil pressure sending unit, but i am not 100% sure about that.
keep me posted on how ur swap goes, and i'll let u know if i find anything that needs to be changed when i put mine in.
good luck
Yeah you'll need to get an oil pressure sending unit (bell shaped thing on OFH) for sure. All my friends get scared when I'm driving my car and my oil pressure gauge reads all the way to the right. Another thing you will want to watch out for is your tachometer not working after the swap. I don't know what part it is that is under/behind the intake manifold that plugs up to give the speedo reading, but I know that part isn't there on mine. Also, you will probably want a coolant filler housing (don't know what it's called exactly, where you put coolant into the car), with sensor and cap and of course new gasket and you'll need the hose that runs off that housing to the reservoir. That's about all I can think of. Have fun guys!
