95 gst wont start
hgould521
47
Jan 25, 2011
Hot Springs, South Dakota
i have a 95 gs-t and am not getting any spark. cas, cps, and pt are all getting power. coil plug is getting power to pin#3 (blue w/stripe). replaced coil pack, and plug wires still no change. please help
sorry its the black w/ white stripe on the coil plug that is getting power. all relays and fusibles links are good as well.
what is the ignitor and where is it located?
also knock sensor is not getting power to it. would that matter and if so which wire should be hot?
pt and coil packs changed, cas and cps both functioning properly. plug wires also replaced. No power to knock sensor would that matter?
The ignitor drives the coils. Its located right by the coil. Usually on the drivers side of the intake manifold. Its black screwed on to a goldish colored bracket.
Not sure if the knock sensor woould cause a no start.
ecu is good swapped out for a known good one and still same problem. Transistor replaced with no change. Wiring is good power to all wires and proper volts. Only thing not getting power is knock sensor can i hook a power wire to it from the battery just to see if it works? Or will the knock sensor cause it to not start? If so which wire do i hook the power wire to?
alright will do first thing in the a.m. and post results thank you
the only thing i could find that fit that description is the pt which i changed out.
