95 awd wont start
Randy08
60
3
Dec 5, 2006
sterling heights, Michigan
was at mcdonalds today car was running great took off and was waiting to turn out of the driveway and it just died and wont start back up. i have been going through very deep snow like 6-9 inches of snow could something of gotten unplugged or messed up under the car? its lowered 2.5 inches also. i think it might be the fuel pump because you don't hear it turn on and the gas gauge has not been working correctly the past 2 days. how can I check for the fuel pump? Please help me out! thanks
-Randy
Check the main engine fuse. I am guessing the car cranks but does not start, correct? If the main engine fuse is good, you need to make sure you are getting fuel and spark so you can isolate the problem. If your not getting spark nor fuel, it could be the ECU.
if you cant hear the fuel pump turn on, then first thing i would is check all your fuses and relays. I doubt its your ecu, but anything is possible. My shit is awd but i didn't have the balls to take it out today because mine sits low also and i didn't want to get any water anywhere. Anyways good luck and if you cant figure out the problem let me know my body owns a performance shop and he is specialized in DSM's and he is in Troy around your area.
