2G 95 gst - 60 amp Fuse(+B) wiring help
athlete3344
426
94
May 1, 2010
Tampa, Florida
Good afternoon!
Im almost done with relocating my fuse box (started this years ago and life happened) and Im on the last couple of wires. I need some help finding 1 of the 2 red wires that comes off the White/Black Stripe wire to the 60A Fuse(+B) fuse. Its the red wire with black stripe. I pulled a wiring diagram and it says the all red wire should go to the 10amp Fuse 11, and the Red/Black Stripe should go to a 10A fuse 8, but im having trouble locating fuse 11 and 8.
In the picture below, I labeled the red wire as A1, and it connects to the 10A fuse labeled Room Lamp Habitacle - Im guessing this is Fuse 11? Blue circled things are optional to answer, but I found 2 relays in another box that have the same part number as the others.
This is the White/Black Stripe wire that connects to the 60 amp Fuse(+B) side. The red wire will get wired to the 10amp fuse in the next picture. I dont know where the red/black stripe wire goes.
Fuses 8 and 11 are highlighted, for each you can see the wire locations for each specific color of wire.
Weirddd, so there's no wires coming from or going to Fuse #8, which is the AC climate control. Is that normal? I dont think I removed those wires. Any thoughts LOL?
I did find these wiring diagrams. Im guessing air conditioner is referencing something in the gauge cluster, prob the A/C button?
That is telling you that it’s leading to the A/C system diagram that you’d need to trace further to figure out where it ultimately runs.
If the car never had A/C (I think it’s unlikely but, hey, it’s a theory), that would explain missing wiring there.
Ok thanks! My guess is I committed to removing the ac from the car a while back. The diagram is very helpful. Going to table the ac project for a later date I think after the car actually runs again.
Thanks for the learning opportunity. It's fun relearning how reference material is put together.
