nikeairz21
- 0
- May 5, 2008
Riverside,
California
is it possible to swap 95 gs 2.0 l into spyder convertible gs? if cant what abt gst?
Help me out guys
Help me out guys
I dont believe it would be worth the effort since I do believe the 2.4 is mounted with the timing belt toward the drivers side like the 4g63. However anything is possible if your willing to do EXCESSIVE amounts of work.
The gs spyder has a 4g64 engine in it. not the 420a engine. The wiring harness is just about the same as the gst. you have a couple of options. One is just add a turbo, exhaust manifold, injectors and a turbo ecu .Or do a complete 4g63 swap.
im wondering if the motor 2.4 from galant between 95 ro 98 will fit 96 eclipse spyder gs? do i have to change something such as motor mount?
