Resolved 95 fuel sensor with 97 wiring
Bedicine
542
190
Jan 3, 2022
Toronto, ON, Canada
Has anyone done the 4 wire to 2 wire conversion for the unit that sits behind the drivers seat in the fuel tank? I have a 97 harness in a gsx but my unit and tank is a 95, currently not able to get any reading on the gas gauge and I’ve even checked a different cluster.
Hoping someone has done this conversion previously?
Going to try this but is this the one you guys had before and modified
Not sure if you guys can confirm that these wires are correct behind the drivers seat unit also. The plug was disconnected and wires pulled out when I got the car
Mine might be a bit different so my harness in the car is a 97 from an awd originally . The gas tank and the harness on top of the tank is a 95 from a awd. Those wires already match up which is why I’m thinking it’s the plug that goes across to the drivers side
Still having the same issue. I was hoping it was the cluster but replaced that over the winter and it didn’t go away. Was actually going to try trouble shooting it this weekend with thinking maybe the float was stuck and then I’d check electrical but mastermatt messaged me and was having the same
Issues so figured I’d open a thread up to try and see if we could trouble shoot both
Just tried grounding out the yellow wire on the drivers side sending unit and the gauges goes up. Guess that leaves me with either a bad sending unit, bad ground or I have pin my yellow wire in the wrong spot on the connector since I repinned it
You should pull your sending unit out and ohm it out. Make sure it reads from the top to the bottom smoothly through out and there isn’t any corrosion on the contacts.
-Daniel
  • For sale 1g MD122260
    Up for sale Discontinued MD122260 Forward Facing Oil Filter Housing $120.00 shipped plus paypal...
  • For sale 1999 Mitsubishi Eclipse GSX 5 Speed
    Selling a 1999 Mitsubishi Eclipse GSX. 5 speed manual, Red on Tan leather. 83,500 miles.
    • radron26
  • For sale 1g Carbon fiber center tail section
    Carbon fiber cover for center tail light light section
    • arodgst
