95 eclipse lighting issue!! HELP
dillonsuperman
Nov 9, 2011
Topeka, Kansas
My 1995 eclipse gst has been have some lighting issues lately. First, the right turn signal hyperlinked, all lights worked but the rear was dim. A new bulb fixed the issue. I put new headlights in, hyperlinked again, load resistors fixed it. Right side hyper blinking again, new rear bulb fixed it. NOW the right side is hyper blinking again and I have replaced all bulbs with no results. Now my reverse lights are dim also. I think the rear right turn signal is shorting out because when I'm driving the gauge turn signal flickers. I have tried messing with all the bulbs and the load resistors which didnt fix the problem. Any help on how to fix this right side hyperlink would be appreciated!! Thank you!!
Have you modified the lighting in you're car? Have you modified anything in regard to wiring? It sounds like there is a short in the lighting circuit, not a short to ground, but a short to power of some kind. Do you have a multimeter?
I have a different CD player and my headlights are HIDs with LED switchback turn signals. I had everything working fine for a while but then it started hyper blinking again. None of the wires for the headlights have been spliced, just wire clips to connect my load resistors in my turn signal wiring.
Have you tried to remove all of the additions that you have made to the lighting system and return the stock components? It could help isolate what the source of the issue is, could be a ballast or something...
