95 Eagle Talon starts and stalls immediately
Alchemy
30
4
Jun 13, 2019
rock springs, Wyoming
Backstory:
I was driving down the interstate, and all of a sudden my Talon stalls.
No biggie. Put it in neutral and try to start. Starts but stalls.
Tow it home
Tries to start again and gets tough idle for ten seconds then dies again
Now it just stalls immediately after starting.
I have replaced the Cam angle sensor, plugs, wires, coil, egr assembly, vacuum lines, injectors, fuel filter and pump, tps, iac, throttle body.
I have good timing, compression, and fuel pressure.
My thoughts are bad ecu. I go to check the inside for leaky caps. Lo and behold, it's filled with polyurethane gel.
My question is, should I replace and see what happens??
