93 Tsi-2g mas or 3'GM w/MAF translator?
sweet97
2,386
18
Mar 6, 2004
auburn, New York
I don't plan on hardcore mods just upgrading the stock systems. What is the current opinion/2G mas or the 3" GM mas with a MAF translator? I would like to consider cost and ease of instalation and tuning. I plan 15PSI. What cars have larger injectors and should I consider them or will I be OK? I have a friend who owns a yard so some may be available. Thanks,the car is not yet registered but getting close. Mark
PS the car of the month is awesome! 500 whp?
are you using the 14b?...if so then you can hit 15-16psi on the stock 1g MAS and injectors...you dont have to get a 2g MAS.
I haven't registered the car yet. Here's the plan:
exhaust, 15psi with boost gauge, Upper IC pipe. 16G EVO III turbo and exhaust manifold and 02 housing. My main questions are sould I go with a 2G mas or the GM 3" mas and a maft and would larger injectors be required. mark
I would go with the GM MAF, but it will cost double if not triple of the setup for a 2g mas. But if you decide to get a 2g mas, I have a 1g-2g mas intake pipe brand new, retails for 110, ill let it go for 75$ (ITS RED) :thumb:
you wont run very well with the 2g maf and stock injkectors...I suggest 550s to balance it out
