92 awd trans problems after bearing install??
Farmcar
39
36
Aug 6, 2013
Portage, Michigan
Yesterday i did the skateboard bearing mod to my 92 awd. I had no previous shifting problem i just wanted to tighten it up a bit. After the bearing install i now have a problem with 5th gear and reverse. It will go into reverse, it just seems rough compared to before. 5th on the other hand feels like its fully engaged but as i let the clutch out it kicks out of gear. Ive read about a washer under the back up light switch, i will check that in the morning but i never messed with that so not sure why it would be a problem now
