91tsi awd auto need help on where to start with the transmission
bisislame
77
Nov 14, 2002
new orleans, Louisiana
i picked up a 91 tsi awd thats auto im planning on keeping it for a while so i figured i had better get transmission taken care of first so what exactly do i need to get done to it to handle lets say stage 2 for starters
translab shift kit? how much would a shop charge me to put it in?
and after the shift kit what else
so far the motor has a big16g and a magnaflow exhaust
any other suggestions :confused:
are you going to drive it on the street alot ? Go with a high stall converter and a shift kit ...as for a turbo seriously consider that without a hs converter you will cut slower 60 ft times than the stick cars .if i was going to build a auto street car i would go with a ball bearing turbo no matter what the size so i could build boost fast against the brake for better light to light mustang battles.....
i kinda wanted it to be a fast and reliable daily driver i know thats almost oxymoronic
so far i ordered the shift kit and the transmission rebuild kit
anything else
Id order an Alto Powerpack and replace the end clutch. I put one in my GSX after I lost OD, had to drive it for a bit, but it worked like a charm. Dont just replace the clutch's though, Go ahead and replace the gaskets and stuff also.
