1G 91 Laser 1.8L
SMCINTYRE
Oct 3, 2024
Evansburg, AB, Canada
After sitting for over 7 years, did a ton of work. Now, Runs just fine when it's first started, but once it warms up it dies.
Thoughts
Thoughts
is there a bad smell in the car? Sounds like ECU caps going out. Common with the 2.0 but not sure about 1.8 if this isn’t your issue then i would think bad gas clogging the fuel system. Or even a bad pump seizing after running awhile. 7 years is a long time to sit
