91 Eclipse part ID
Russman1986
70
Apr 15, 2009
Decatur, Illinois
I need the part that connects the headlamp assembly to the actuator.
The light flips down but it pops off the ball when flipping up.
I cant find a diagram of the flip lights. The part is like a tie rod that fits on a ball, one side was white one black on allthred with two bolts to to lock the length. Looks kind of like a ball joint on the end of the lever that moves headlight. What is the name of the part.
Thanks for your help.
My camera is busted,sorry for sounding like a noob.
I only knew them as headlamp linkages.
I know up here in the rust belt that used to happen quite a bit.
Once the door linkages got enough resistance from corrsion the links would pop off.
used to have to clean them up best as possible & lube up all the moving points in the doors to get them to work correctly.
91' Eclipse GSX
If this is the diagram you mean, let me know what number you need and I'll tell you the part number / name
You prob don't need the linkages, unless the plastic ends are cracked. Most likely, you have corrosion on the assembly itself. Take out the headlight assembly and take some light sand paper to the "frame," followed by some grease. Pop the linkages back on and they'll work like new.
80043 - MB606225 - LINK,HEADLAMP POP UP
80044AL - MB542477 - MOTOR ASSY,HEADLAMP POP UP,LH
80044AR - MB542478 - MOTOR ASSY,HEADLAMP POP UP,RH
80043 is just the link by itself, while 80044AL (and 80044AR) is the whole assembly. The R and L at the end of the part number just means left or right hand side, as seen from sitting in the drivers seat.
For a '91 Eclipse GSX
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
