91+ coil pack in a 90 gst
black_gst
2,467
29
Jun 16, 2008
IE, California
ok so i have done some searching and came up with nothing clear at least
my friend has a 90 gst and its throwing a code for the coil pack.
i have a working coil pack with the 3 wire plug and a 90 uses the 4 wire plug
my question is, is it possible to swap coil packs by rewireing the plugs? i know it may result in the tach not working, but the tach already doesnt work so its not an issue.
thanks
i was looking at maybe doing that but the 90 coil pack has extra parts on it that a 91+ doesnt i dont know what they are but they are somewhat different. what im really trying to get at is what is the extra wire on the 90 for, is it just a ground?
the plugs are different, one is square and one is triangular. the bracket is not my problem... if you have swapped a square plug to a triangular plug please elaborate on how you did it.
from 91+ they all have a triangular 3 wire plug before that they were square 4 wire plugs
The extra parts on that 90 coil pack is for the tach.
you can just cut the plug off the 90 and match the colours from the 91 plug. The extra wire on the coil side that doesnt match, dont hook up.
The transistor pack in the 91+ does the tach conversion.
You can wire other coils into a 1990. I used a 95 coil. Just be sure to wire exactly how the 90 was. The tach will work as well. You will have to get creative on mounting the tach box and the transistor but it will work.
