90 Talon TSI front wheel Hub assemblies???
sergiosdsm
110
Nov 5, 2002
New Jersey
The front wheel bearings on my car are toasted and I dont want to go through the trouble of taking them out and having messed up hub assemblies. I want to fix it the right way and I would prefer to get the front hub assemblies with the bearings already packed and ready to go.The local parts stores dont have a listing and my last resort would be the dealer. I need help finding the best price for front hub assemblies for my 90 awd talon tsi. thanks in advance .
I don't know if you have found what you are looking for yet, but there are no hub assys. The wheel bearing is pressed into the knuckle and the hub is then pressed into the bearing. I doubt you will have much luck getting a new knuckle with bearing and hub already assembled, try a junkyard. There is also no packing to worry about, they are sealed bearings held in by press fit and a snap ring. The proper way to fix it is press out the hub, remove snap ring, then press out old bearing and press new one in.
If you have found a complete assy new, please post and let us know that your car is fixed and where you found the part.
The wheel bearing and hub assemblies are seperate, buying a new assembly would still require it to be pressed in, which wouldnt be easy with the hub already on the bearing. If you have a press it isnt too bad and I could walk to you through it if you decide to go that route
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
