2G wheel hub differences?
Dude3000zx
120
Mar 11, 2010
Athens, Alabama
Just wondering if there is any difference between the hubs year to year and abs and non abs.
I had to have passenger side hub replaced when i bought the car and im pretty sure they used an abs hub not sure what year.
Reason im wondering is because i have a problem with ride height difference between driver side and passenger side, trying to find the problem.
can the hub assembly effect ride height?
thanks
There are minor differences on v.late model 2Gs, but only in the rotor centering area.
Hubs will not affect ride height - if your car is like most, then it's simply the way it came from the factory. To get ride heights correct at all 4 corners requires adjustable spring platforms, aka coil-overs.
Charles
